Rocker Adjustment
Rocker Adjustment
I just went threw and adjusted half of my rockers. (left side of engine) I did the deal where you tighton and twist pushrods till you feel friction then tighton 1/2 turn more. I was wondering does every rocker have to be as exact as the others. I tried my best to keep them the same but im just wondering do they have to be perfect?
Thanks for your help.
another question. It looks like the pushrods are flaring out a little like a V. the left rode is leaning to the left a little and the right one is leaning to the right. This is after they are adjusted. Is this normal?
the rockers are SA. they are seated fine on the valve stem. it looks like the lifters are not centerd exactly under the rockers. So the pushrods dont go strait down. they slant down like a V. for example the pushrods are 3mm further apart by the rockerarms then they are by the lifters
I don't remember how parallel mine were, but they are NSA anyway. If your SA rockers are correctly locating on the valves, and the pushrods are centered on the lifters, and you didn't redrill the studs in new locations, I see no way for variation in that angle. So I think it must be normal. Unless you got offset rockers somehow.
RUENUF
Mar 13, 2016 03:37 PM
