This is the right harness for my model year, right?
I am going to be suing a Mallory 685 box, is this the ignition wiring harness I need?
http://store.summitracing.com/partde...0&autoview=sku
It is a 94
It is a 94
I don't believe you need an adapter harness for this application. Per Mallory: "everything that goes to the negative side of the coil is junctioned to the green wire and everything that goes to the positive side of the coil is junctioned to the small red wire". Use soldier to make your connections. You may even want to try calling Mallory's Tech line @ 216-688-8300 to see if they can work up a wiring diagram for you. They currently do not include that diagram in thier instruction manual, but if they send you one, it may be a good idea to post it for other peoples future use.
F'n1996Z28SS
08-23-2023 11:19 PM
25thTA
18
07-08-2002 09:41 AM
Darth Xed
12
06-27-2002 07:46 PM
jrp4uc
12
06-26-2002 01:57 AM
guionM
14
06-19-2002 08:30 AM
