CamaroZ28.Com Message Board
-   -   resistor to replace low oil level sensor (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/resistor-replace-low-oil-level-sensor-455201/)
steve40 Jun 10, 2006 12:59 PM
currently building a 383 with a moroso oil pan. the pan does not have a bung for the low oil level sensor. does anyone know what resistor i could put across the wires to keep the light off on the dash?
thanks
steve
Dave89IROC Jun 10, 2006 01:10 PM
Re: resistor to replace low oil level sensor
unplug it, if the light is on, cross the wires, no resistor, it is just a on/off switch
user 647483 Jun 10, 2006 01:29 PM
Is there any way to have a bung installed?
If it's not too much of a pain, I'd try to keep the sensor for peice of mind.
96flame Jun 10, 2006 02:21 PM
All you need to do is cut the plug off and join the wires together.
