Replacing plug wires
Old Jan 5, 2005 | 06:48 PM
kicksZ28's Avatar
Cool Replacing plug wires
I am looking to replace the original plug wires on my 95 Z28. Can someone advise on a good replacement brand and what style? I was looking at MSD. I have upgraded the original coil with a MSD. Was also looking at MSD new cap and rotor, any suggestions? Thanks
Old Jan 5, 2005 | 06:50 PM
Bersaglieri's Avatar
Re: Replacing plug wires
I love my MSD Superconductors, easy install, look awesome and worked great with my headers. I think the lowest price on them is summit. Cant go wrong with those, they are great. Opti wise I went with a full GM replacement from Dal at VanDevere. Lowest price on optisparks in the country.
-Dustin-
Old Jan 5, 2005 | 07:14 PM
Hawk's Avatar
do a search on routing your wires over the valve covers. Makes them look alot nicer, and also alot easier to change later. THis is really good if you have headers.
Brian
Old Jan 5, 2005 | 08:18 PM
Kataklysm's Avatar
Replace the whole optispark, don't just replace the "cap and rotor"
Old Jan 5, 2005 | 11:41 PM
OBE1 95Z28's Avatar
I had bad luck with my MSD wires; the boots were very soft and wouldn't stand up to mild abuse. Also the 8.5mm diameter will not fit in the stock routing postion. I'm presently running Accel 9000 8 mm wires. Nicely built, robust and will fit in the stock routing. They also stand up great to the heat.
Old Jan 8, 2005 | 12:29 AM
Bud M's Avatar
Another vote for Accel 9000s. I've put them on two LT1 Camaros, no problems.
I would not buy a cap and rotor, just spend the extra on a new opti if you need one.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Fatdog2
Feb 13, 2015 08:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jazsun
Dec 29, 2014 12:14 PM
