CamaroZ28.Com Message Board
-   -   Replacing Head gasket?? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/replacing-head-gasket-225230/)
95BlackTA Feb 15, 2004 05:52 PM
Ok I have to fix my intake manifold leak. Once i have the intake off, how much harder/longer would it take to replace the head gaskets? I MIGHT have a head gasket leak, but im not sure.
ANy pics of doing the head gasket, any special tools needed?
Zack Feb 15, 2004 05:56 PM
make sure you figure out the symptons to be a blown head gasket. Its not a fun task, since it requires removal of the exhaust manifolds...not fun.
other than that, I havent found the need for special tools yet
lt1g3n Feb 15, 2004 06:26 PM
yea i would try to make sure you have a head gasket leak before you take the heads off ... be positive , because its not something you want to do unless you have to :).. only reason im doing it now is because i got 'new' heads , to me it's all fun as hell.. but only because it's a new part :) ...
