Replacement Radiator Question
Old Oct 22, 2010 | 12:38 AM
whytry2002's Avatar
Hello,
My radiator cracked at the tank and I bought a replacement radiator. I got it off of genesisautoparts.com There were two available, 1 and 2 row. I figure why not pay a bit more and get a more efficient radiator. I got via FedEx and took it out and noticed 2 AN fittings on it that are not on my old radiator, the rest match perfectly.
Here is a picture of what I'm talking:
Old radiator:
New radiator:
I filled up the new radiator with water and it wasn't leaking from the 2 extra fittings, it seems the 2 row in the radiator is separated. So I'm pretty sure those are for extra component cooling, like power steering or engine oil.
My question is, if I can't return this one for a regular 1 row radiator, can I just keep this one and do I need to weld/plug those fittings securely?
Old Oct 22, 2010 | 12:47 AM
henryz28's Avatar
I think those are for the trans lines. My 1996 has two trans lines running to the passenger side. I guess you could just cap those off.
Old Oct 22, 2010 | 01:13 AM
whytry2002's Avatar
Thanks, looks like it. A couple of people on ls1.com forum also said it's for automatic transmission.
They also said, all aftermarket radiators come with that so I guess I'll just plug it up.
Old Oct 22, 2010 | 02:21 AM
Mswezey's Avatar
From: Wichita Falls, Texas - College. DF-Dub, when not in college
it's for the automatic tranny fluid
nothing to worry about. plug it so nothing gets in there i guess.
Old Oct 22, 2010 | 06:44 AM
Replacement radiators often have the transmission cooler so that they don't have to go to the expense of supplying a separate model. One radiator fits all. The fittings are ignored on a manual transmission car.
sscott
Jan 17, 2015 04:30 PM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
