replaced head gaskets now no start
Old May 3, 2008 | 08:36 AM
ARZ28's Avatar
1994 z28 lt1 replaced head gaskets and all the other top end gaskets and any parts and pieces that i broke.now the car wont start.it ran with the bad head gaskets and blew smoke and now i fixed that and it will not fire.it ran for about 4 seconds and then died.it does turn over but will not fire.the fuel pump turns on when you turn the key and i can get a wiff of gas when trying to start it.is there anything that im supposed to do to get it ready before it will fire from fixing the top end.thanks
Old May 3, 2008 | 08:55 AM
caldercay's Avatar
You need to double-check all connections, such as at the Opti, plug
wires, wiring to the PCM, to the injectors, and so on. You need to also
check all mechanical connections, such as the intake elbow and so on.
(For example: I've had the bottom run of the intake elbow buckle while
sliding it back on - didnt realize it - when I cranked it up, it ran like
cr@p, so double-checked everything I removed, when I noticed the
buckled rubber seal, which meant a large leak).
Old May 3, 2008 | 02:23 PM
ARZ28's Avatar
any other ideas
Old May 3, 2008 | 03:28 PM
Nitelite's Avatar
Possibly ruined the opti from getting coolant on it?
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
