Removing Motor mounts?
In order to remove the bushing, do i need to drill/chisel the rivets out?
Basically Im buying some poly mounts and need to remove the stock ones, and will the new ones come with the hardware to replace those rivets? |
Yes, you'll need to drill out the spot welds that hold them together. The kit should come with some zipties which will hold the pieces together until you bolt them down.
well, i was only looking at the drivers side mount when i posted this. how do you go about removing the passenger side? it doesnt have any welds?
ttt for the passenger one.
Same proccedure, drill out the spot welds and replace the rubber part in the middle.
i didnt see any welds on the pass sdie, looked like it was pressed together! guess ill look in the morning
| All times are GMT -5. The time now is 08:43 AM. |
