Removing engine from top... Do I need to remove headers?
Pulling my motor from the top tomorrow. I have Pacesetter longtube headers and was wondering if it is possible to just unbolt the headers and move them to the side a few inches, or do I need to fully remove the headers to pull the motor from the top?
Jeff |
i would,you will need all the room you can get
I unbolted mine and set them back till I started raising the engine out , then when I had enough room I pulled them out the way .
We pulled mine out with STOCK manifolds attached, but thats not where near longtubes. I think iv heard other people (outside of this thread) say to just lay them off to the side.
Manifolds no. Headers yes.
i just did it and left the headers in, worked completely fine..
i was able to remove the motor by just using zip ties to hold the headers as close as they could get to the wheel wells with out a problem
stocks and shorties come out with motor. long tubes i laid to the side. and then pulled out when i had room.
i just pulled my engine out with long tubes,and left them in worked fine.
I had to pull the long tubes off to the side and pulled the motor from the top.
