Removing air/egr/cat
Old Sep 15, 2007 | 06:57 PM
NemesisLT1's Avatar
I have a 94 formula, I will be installing some Mac midlength headers (94/95) with no emissions soon. I was wondering what will happen if I remove all the egr/air stuff... will it throw codes or not? and will my gas mileage suffer? also I was told that sometimes the rear cat will throw a code, othertimes it wont, if its removed?
thanks
Old Sep 15, 2007 | 07:11 PM
raroz28's Avatar
My air never worked. When I did my heads/cam I removed the air and it didn't make a difference.
I got 26.6 MPG going to Pennsylvania.
It's simple to remove, but it's a PITA to get the tube that runs under the timing cover off. I had to cut mine.
EGR might affect gas mileage, I'm not sure.
I would leave that lone if it's working fine.
Yes, removing either of those will throw codes. You will need to tune the computer to disable them.
Old Sep 15, 2007 | 09:38 PM
95Blackhawk's Avatar
Removing EGR will throw a code but not AIR on a 94.
That tube is a bitch to get off going to the pass. side. The way I eventually got it off is by rebuilding and having full access to my engine.
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
