Removeal of AIR and EGR
You'll need to order the block off plates from http://www.sjmmanufacturing.homestea...Order_Form.htm You will also have to have the computer reprogramed to delete them. You remove the egr and air stuff and replace them with the block off plates, you'll also have to plug off the nipple on the intake where the EGR gets its vacuum from.
EDIT: Here is a really good thread on the topic.. http://web.camaross.com/forums/showt...m&pagenumber=1
Originally posted by FacelessZ
you dont need to order plates from anywhere. cut a piece of aluminum or tin and use it as a blockoff plate instead of spending $20+ on a custom one...
stockssn2o
May 25, 2015 08:54 AM
95chwagon
Jan 13, 2015 09:19 PM
