Remove EGR
Old Apr 16, 2003 | 01:25 PM
MyTMous's Avatar
Remove EGR
Will it hurt anything to remove the ERG and block it off.
I'm going to a cam that won't need the egr but I was wanting to do this and the AIR when I put my hedders in. but before I get the cam, so can I do this without it messing up the PCM or driveablity problems. I will drive it 1-2 months before the cam install.
Old Apr 16, 2003 | 02:05 PM
GREGG 97Z's Avatar
Removing the EGR isn't going to hurt anything, I don't think you even get an SES code for removing it on OBDI (94/95) I know you do for OBDII though (96/97)
Old Apr 16, 2003 | 02:06 PM
LWillmann's Avatar
You'll probably get an SES light until you get that stuff programmed out of the PCM...
EGR removal has no affect on WOT performance but it will affect part-throttle cruising...
Old Apr 16, 2003 | 02:15 PM
CGrant's Avatar
I have had my egr blocked off for like 2 years now, No problems.
It's a 95
Old Apr 16, 2003 | 02:44 PM
LWillmann's Avatar
Must be because you are OBDI and I am OBDII... I forget about that sometimes...
Old Apr 16, 2003 | 04:13 PM
MyTMous's Avatar
I've got tuner cats so I can turn it off in the pcm, What kind of part throttle problems does it cause??
Boss002
Jan 20, 2016 12:17 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
