Which regulator needed??
Ok i am putting together a 383 on a LE3 heads/cam setup and need to know what brand and all that of a fuel pressure regulator will work good and doesn't cost the same as the stroker? The Aeromotive LT1 Rail Mount Adjustable Regulator looks good but not sure.
Re: Which regulator needed??
If the stocker works keep it, there are very limited reasons one TRUELY needs an AFPR, I see nothing in your combo that dictates it. I know guys here like to tell you you can tune a car with one but they are wrong.
