Rear Main Seal
Old Mar 23, 2005 | 06:27 PM
Hawk350's Avatar
Rear Main Seal
I will be replacing the rear main seal on my motor. I have the trann removed, flywheel is off. Do I just rip the seal off where the crank is? Drop the pan and replace that one too? Has anyone done this before? Some tips would be helpful.
Old Mar 23, 2005 | 06:36 PM
ManicHaze's Avatar
Re: Rear Main Seal
i could be wrong but i THINK its one of the pop in type seals. A friend of mine did it to my car back when I got the tranny rebuilt. If i remember correctly he did not have to remove the oil pan. I could be wrong so dont quote me on this.
hope that helps
Old Mar 23, 2005 | 06:41 PM
Pasky's Avatar
Re: Rear Main Seal
Flywheel just needs to come off. Get a seal puller or scrwew driver to pry the old one off then put the new one in.
Old Mar 23, 2005 | 06:42 PM
FuryZ28's Avatar
Re: Rear Main Seal
Are you SURE it's your rear main seal that's bad? I thought mine was bad, and turned out to be the classic "rear intake manifold leak"...
Old Mar 23, 2005 | 06:47 PM
Hawk350's Avatar
Re: Rear Main Seal
yeah, it's leaking....each time i drove the car, there would be a few droplets of oil. it's not from my intake. I have he seal kit and there is like 3 pieces to it.
Old Mar 23, 2005 | 06:53 PM
Hawk350's Avatar
Re: Rear Main Seal
I have some pics that I will post links to when i get home. You guys can give me your opinions.
Old Mar 23, 2005 | 06:56 PM
fstenuf's Avatar
Re: Rear Main Seal
i thought there was a special installation tool required? idk for sure so don't qoute me on that
Pasky's Avatar
Re: Rear Main Seal
Nope, i've always used something round and a hammer. For the old style cars they used to have a snake that would go in and grab the rear main seal.
Old Mar 23, 2005 | 07:17 PM
Re: Rear Main Seal
If all that is leaking is the round piece going around the crank, then that is all you need to replace. No need to remove the pan or the seal housing. No special tools required to remove. Install like you would any round seal.
Old Mar 23, 2005 | 07:20 PM
95RagtopTA's Avatar
Re: Rear Main Seal
Replaced mine when I put in my Spec 3... I went to Home Depot and sized up the seal with a PVC pipe adapter (or just buy a piece of PVC conduit)--I think it was around 4", cost less than $2. Put the seal in place, then the PVC pipe, a piece of wood and hit it with a rubber mallat a few times. ALSO, before removing the original seal, look to see how far it goes into the crank, this will help you to determine how far to drive the new seal in. I also had a leak around that area--as a precaution, I put a bunch of black RTV (the Right Stuff--Napa) around the rear of my oil pan gasket. So far, no leaks.....
Old Mar 23, 2005 | 10:48 PM
Hawk350's Avatar
Re: Rear Main Seal
Here is a link to a picture...it's definately leaking
http://pro-mos.com/gixxer/oil2.jpg
Old Mar 23, 2005 | 10:53 PM
Re: Rear Main Seal
Depending on how many miles are on it, you might want to think about changing the pilot bearing while you have access to it.
Old Mar 23, 2005 | 10:54 PM
Hawk350's Avatar
Re: Rear Main Seal
the car is a 1994 and has 26k. I will replace pilot bearing and seal. It does seem like its a leaker right?
Old Mar 23, 2005 | 10:56 PM
Hawk350's Avatar
Re: Rear Main Seal
when replacing the bottom one, is there a poxy or glue i need to use? Or is it just take the old one out and put the new one in?
Old Mar 23, 2005 | 11:06 PM
Pasky's Avatar
Re: Rear Main Seal
I always put a little oil around the lips of the new seal to be sure it doesn't burn up. Thats all that is necessary.
