Rear distributor in F-Body
Re: Rear distributor in F-Body
There have been several threads about this. Lt1intake.com can drill the back for you.
http://web.camaross.com/forums/showthread.php?t=310918
thanks, I was going to scrap the opti and get a LT1 Intake Aluminum Manifold, with a carb, rear dist... etc. My car breaks up bad and I have been screwing around for months without getting anywhere. I have finnaly gave up.
Actually, all the F-bodies produced from 1967 thru 1992 had "rear distributors".
I guess you are referring to the 4th gen.
With the intake modified, you can get it in there without cutting anything. Most people are running the crab style caps to gain a little clearance.
Swapping to a carb will give you problems passing emsissions, so be aware.
I guess you are referring to the 4th gen.With the intake modified, you can get it in there without cutting anything. Most people are running the crab style caps to gain a little clearance.
