| Green95Z28 |
Feb 11, 2006 07:29 PM |
REALLY rough idle
My car has been running REALLLLLY rough ever since i put this new motor in. I can't for the life of me figure it out. It is a stock motor with a lt4 hot cam in a 93 z28. I had the thing tuned to no avail, the computer reads the right bank as going really rich then it leans it out so bad that the whole car starts shaking and it cuts out til about 2200 rpm. I have replaced o2 sensors, changed spark plug wires, re-adjusted the valves, put new ford racing injectors in, put the stock chip back in, all of this to no avail. The engine is also leaking oil from what I can tell at the water pump drive, could this have fubared the opti? ANY help would be GREATLY appreciated, as this is dang near un drivable.. The problem seems to get a LOOOOT worse when the engine warms up or I have been idling for a while. When I first start it it runs great. Also if I shut it off to get gas and get back in it, the engine surges HARD under a load IE when I take off from a dead stop but then clears up at above the 2200 rpm mark.... Again, Thank you very much!
