re torquing heads after replacing head gasket
Old Aug 9, 2006 | 07:58 PM
Bandit95LT1's Avatar
i blew a head gasket a couple of months ago. someone ask if i had re torqued the heads. my question is , is this important and has anyone herd of this?
Old Aug 9, 2006 | 08:03 PM
wrd1972's Avatar
Re: re torquing heads after replacing head gasket
Dude, it is vital to properly torque all major fasteners such as head bolts, intake bolts to ensure that tolerances and fit are correct and to prevent things from backing out. If you did not properly torque your head bolts then you need to do it or you really risk blowing another head gasket.
Old Aug 9, 2006 | 08:11 PM
Dude i did torque them.but my question is bout RE-torquing the heads.
Old Aug 9, 2006 | 08:14 PM
wrd1972's Avatar
My bad. If you torqued them correctly I think you are good to go.
Old Aug 9, 2006 | 08:27 PM
SSCamaro's Avatar
Some heads/gaskets you do and some you dont. Some designs felpro redesigned and you do not have retorque on some heads you use to have to. I dont know abut the LT1's but always wondered if that was a good idea on a 100k LT1 engine for preventive maintnance!?
Old Aug 9, 2006 | 09:30 PM
Kevin Blown 95 TA's Avatar
I did it on my new engine since it had MLS gaskets & ARP studs, but I also had new fasteners that hadn't been heat cycled. It was a super PITA to do because I had to drop the headers and remove the rocker arms which I really didn't want to do. After it was done, I was happy I did it.
For stock type gaskets with seasoned fasteners, I don't see why you would need to do it.
Old Aug 9, 2006 | 09:52 PM
Severous01's Avatar
i didnt and i'm running on about 5k miles with no problems...other than piston slap...but that's another problem alltogether.
i wouldnt worry about it if you used quality gaskets. or...if you're going to replace your rockers you might want to go ahead and touch them up while the covers are off.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
