Radiator question
Old Sep 22, 2009 | 07:10 PM
Dave1980's Avatar
Radiator question
I had my radiator in my garage when some people came to work on the sheetrock after the hurricane here in houston. I previously had it cleaned/refurbished by a radiator shop for my build. After getting back to the project I noticed there is a gash/dent that was not there before in the radiator now. I tried my best when clearing out all of the stuff in my garage, and thought the radiator was in a safe place against the wall, only to find damage to it. I suspect one of the workers hit it and didn't realize it.
I got pissed, but of course its partially my fault for where I left it. I am either going to get it repaired or get a new one.
I got to thinking about my options and my build. Is the stock radiator going to be sufficient with 11.8-12.1 CR range in the south?
A/C is a must here, and want to know my options for aftermarket. I remember somebody having clearance issues with a EWP and aftermarket radiatior.
I am just looking for opinions I guess.
Old Sep 23, 2009 | 09:33 AM
Dave1980's Avatar
Am I in the wrong section?
Old Sep 23, 2009 | 10:34 AM
'94 Bad A Z28's Avatar
My 383 is 11.8:1 and my car never gets above 175* with the stock radiator.
I'm in Fl, so it is hot here year round.
Old Sep 23, 2009 | 12:46 PM
Z28SORR's Avatar
Griffin and Be Cool are the two most commonly purchased aluminum rads. Check Summit or Jegs. Or stop by Clear Lake Speed in Sea Brook on 146. However I think a stock rad. should work.
WHY are you going this high on compression for a steet car??? If your running pump gas I would think your just forcing the engine into "knock retard" and losing power.
Old Sep 23, 2009 | 02:41 PM
Dave1980's Avatar
WHY are yo going this high on compression for a steet car??? If your running pump gas I would think your just forcing the engine into "knock retard" and losing power.
Of the 2 types of aftermarket radiators, are they plug in types, or do they need work to get to fit. I am leaning toward stock, and want to see if the radiator shop around me can do anything to improve it.
I arrived at my compression with the le3 H/C combo along with 0 decking my block and using recommended pistons from Lloyd. I comfirmed with him that I would be running 93 and he assured me it would be ok, as long I used the 1074 head gasket.
I will be keeping my eye on the retard along with other parameters once this gets up and running. The car will be a weekend car only. Street/strip. I have heard of a few on here running this type compression on street. I am guessing this is getting close to the limit.
Old Sep 24, 2009 | 10:09 AM
Z28SORR's Avatar
OK! Like I said, check Summit. Both should have direct fit rads.
calaban
May 18, 2020 06:43 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
grgguy
17
Feb 23, 2015 07:57 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
