Quitting on its self
My 95 Z28 will start up fine, idle for about 10-15 minutes then die. Ill let it sit for about 5 minutes, and it will start right up again, and do the same thing in another 10-15 min. Sometimes (not all the time), the car wont start unless i pump the gas. It wont idle wen it does that, or will it run at a constant rpm, you have to keep revving it up, and letting it fall over and over... If I try to drive it at all, it acts like its starving for fuel, even though I checked fuel pressure and spark. Once the car dies, there is no spark at any spark plug. Coil and ICM are new as of yesterday. Any ideas (Opti?)
cmsmith
Sep 14, 2015 09:09 PM
