Quick spark plug question
Old Nov 20, 2003 | 02:58 PM
Zerosheaven's Avatar
I need to do a tune up and alot of people have recomended the ngk tr55. I just wanna know if these are nitruous OK, and will hold up if i do future mods to the car. IE planning on doing a lt4 conversion alogn with all bolt ons. thanks.
Old Nov 20, 2003 | 04:36 PM
Fuels94TA's Avatar
The NGK TR55 are stock heat range plugs. This is not good for nitrous use. You will need a colder plug range.
Vinny
Old Nov 20, 2003 | 04:52 PM
RamAir95TA's Avatar
NGK TR6s.
They are a colder range plug with a narrower gap, to prevent blowing out the spark under increased cylinder pressures during nitrous use.
Old Nov 20, 2003 | 06:42 PM
sounds good,
but is the colder plug safe to use if you dont spray often? or do u need to switch em out?
Old Nov 24, 2003 | 08:42 PM
anyone have the answer?
Old Nov 24, 2003 | 08:47 PM
Z28ROC's Avatar
Sure, Tr6s or autolite 104s are fine for N/A and nitrous use. I personally prefer the autolites for N20 use. I run the 103s.
Old Nov 24, 2003 | 11:22 PM
Fuels94TA's Avatar
I use autolite #104 with no problems what so ever.
Vinny
mritter1965
Feb 9, 2015 07:01 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
