Quick Question, need quick answer!!
I'm ordering BMR LCA's and Relocation brackets as we speak but on Thunder Racing i noticed u can get the Tubular ones with Ploy/Ploy bushings or Rubber/Poly bushings, whats the diff? What should i get.. The cars a Fast Street car, i do alot of Cruising and once per week i go horse around on the dragstrip with my buddies to see who can post the fastest times.. What should i get??
Mike |
If the BMR ones also have poly bushings, then there really isn't much of a difference. If the BMR ones have chromemoly rod ends, then I'd get those. The units with the rod ends will allow you to make adjustments to your rear so you can tune your setup more to your liking.
| All times are GMT -5. The time now is 06:10 AM. |
