Quick Question
i have a 1996 camaro Z28. Leaving work, at 50mph. The car dies. And wont restart. it threw 3 codes.
P0300 Random/Multi Cylinder Misfire. P0141 Bank 1 Sensor 2 Heater Malfunction P0410 Secondary Air Injection System Malfunction. ive replaced every sensor i could find on top of the motor, the opti, icm, coil, fuel pump, fuel pump relay, 2 burnt injectors, and the crank position sensor in less than a year. ive about had it with this car leaving me sitting. any help would be greatly appreciated! |
Re: Quick Question
Do you by chance have a water pump leak? Coolant and opti's dont go well together and it somehow manages to get inside an opti thats not brand new. Other than that, I would say check yer pigtail to the opti. Check fuel pressure is adequate, might have a pressure regulator issue under load. Other possibility is a clogged cat. See if you got good exhaust flow while someone revs the engine, after its hot of course since thats when yer having issues.
Re: Quick Question
Have you checked for a faulty ignition switch?
Re: Quick Question
It looks like you ignored a lot what the trouble codes were telling you. There was no need to replace every sensor and some of those other things. I don't see where you refer to spark plug wires or plugs. That would be the first place to go with multiple misfires. You should also have looked into changing the O2 sensors. The code for the AIR system is a common one and is usually just a blown fuse.
Clear all your codes and when the trouble returns, scan again to see what comes back. |
Re: Quick Question
the 02 sensor is less than 6 months old. just replaced the plug to the opti. the water pump isnt leaking. and i cant get the car to start at all. i was having issues with it about 8 months ago. the opti stopped working and it burnt 2 injectors. water in the gas is what i was told. fixed that then it tore up again. i replaced the pigtail to the opti. fixed the problem. plugs and plug wires are almost 7 months old. my gut tells me....with the water in the tank problem, multi random cylinder misfire. im thinking it might have jumped time. but i cant be sure. not really wanting to dump another 2 grand in it playin the guessing game.
Re: Quick Question
Originally Posted by Injuneer
(Post 6903251)
Re: Quick Question
Originally Posted by MgodzNightwoop
(Post 6903362)
a faulty ignition switch wouldnt allow the car to turn over would it? the security light isnt staying on. it comes on when u turn the car on but when u go to crank it, it turns but wont start. so im not thinkin its a switch issue....am i wrong?
Re: Quick Question
(Post 6903366)
When I asked the question about the ignition switch, you had not made us aware that it cranks when you turn the key. You indicate the car shut off and would not start. My question was based on the limited info you supplied. You left us with the impression it was an intermittent problem.
Re: Quick Question
Turn over and crank really mean the same thing (to most people).
Two basic questions...does it have good fuel pressure (assuming it has good fuel) and is it getting spark to the plugs? |
Re: Quick Question
Originally Posted by shoebox
(Post 6903435)
Re: Quick Question
The correct way to check the fuel pump is to measure the pressure with a gauge. The pump primes ("pulls up"??) but will not continue to operate unless the PCM provides the signal to the fuel pump relay. The PCM will not do that if there is a problem with the theft deterrant system, or a problem with the low resolution pulse signal from the Opti. If there is a code for the IC Module, the PCM will not activate the injectors. Presence of fuel peeing out the Schrader vavle does not confirm the engine is getting fuel.
The codes for the Opti and the ICM typically do not turn on the SES light. Might be worth scanning for codes again. You can check for spark by pulling a wire off a plug and holding it near the block to see if there is a spark. |
Re: Quick Question
(Post 6903445)
The codes for the Opti and the ICM typically do not turn on the SES light. Might be worth scanning for codes again. You can check for spark by pulling a wire off a plug and holding it near the block to see if there is a spark. If yer security light stays on its an issue with the VATS. I was unclear of your response that it comes on when you cycle the key. If not operating properly it will crank, but not start. Does it come on and stay on, or go out? Listen to what were telling you, u got some of the best lt1 experts here trying to help you, but if you dont listen we cant help you. Oh, and ive yet to see an lt1 jump timing. Ive put 400+ hp through a used timing set many times. Not to say it couldnt happen, but ive never seen it. Basic engine driveability, you need fuel, compression, and a correctly timed spark. These engines like to pop head gaskets, but usually you are aware this has happened when u start overheating. Assuming you have compression and this is not the case, first thing I would do is check for spark. If you have spark, id spray some starting fluid in the intake through a vacuum port (MAF must be hooked up to intake tube to run). If it runs, you know its a fuel issue. |
Re: Quick Question
(Post 6903445)
Re: Quick Question
Originally Posted by blown94
(Post 6903523)
+1 need to check spark, and i might add since our wires are so hard to get to, u can just check right from the coil wire first. If u have spark from coil to opti, then try a plug wire itself to see it spark making out the opti. Question, where did you get the opti from and was it new or reman?
Re: Quick Question
for all of u thats helping me with this. just wanted to say i greatly appreciate it!
| All times are GMT -5. The time now is 09:06 AM. |
