Quick question!
I had my motor built a motor shop local.after it was done i put it in my garage to put some other stuff on to it.i then ordered heads 2 weeks after that.i since then torqued the heads down to the block.i went to the motor shop before and the guy said that i should check to see if the valve hits the piston.do i really have to take the heads off and do that or am i fine?
heads-trickflows |
If there is anything non-standard about it, piston to valve clearance should be checked.
Rich |
| All times are GMT -5. The time now is 08:20 AM. |
