Quick Pacesetter LT header question
Old Mar 23, 2005 | 05:38 PM
Bawls's Avatar
Is the first bolt hole on #2 cylinder used?
Here's why I ask.
http://home.comcast.net/~bsmith84/to...ardown-009.jpg
That's the only bolt that broke. If it's not a used hole then I'll just leave it be.
Old Mar 23, 2005 | 05:41 PM
fesgali's Avatar
Re: Quick Pacesetter LT header question
i think this is right...The first hole is used by the stock manifolds and it's used for a alternator mounting bracket. Aftermarket headers use the 2nd hole and on.
Old Mar 23, 2005 | 05:43 PM
Bawls's Avatar
I must have my cylinder numbers mixed. This is on the drivers side head.
I believe the headers will just use the 2nd hole on.
Old Mar 23, 2005 | 06:03 PM
Beyonce Knowles's Avatar
You should be fine. I think I broke the same one when I did mine. Just line your new gaskets up and see, that way you'll know for sure.
alex5366
Feb 17, 2015 09:07 AM
Jazsun
Dec 29, 2014 12:14 PM
