Quick dash question
Old Nov 20, 2003 | 07:12 AM
cocheese's Avatar
Question Quick dash question
I just got my new dash yesterday to replace my cracked one, and I was wandering if anyone knew the best/easiest way to replace it. If you could give me some kind of guide or point the way that would be great!! It probably isn't that hard but i don't want to risk breaking anything (like the new one!) because i did it incorrectly. Thanks in advance guys!
Ryan
Old Nov 20, 2003 | 07:46 AM
zoso1959's Avatar
Re: Quick dash question
Ryan
HI RYRAN
I wanted to ask you question about your ss cragars
when I asked about cragrs for my t/a they said it wouldn't work
because of the back spacing?
i'm sure we have the same back spacing, how did you get yours to fit?
tony
Old Nov 20, 2003 | 07:56 AM
94B&RZ-28's Avatar
Just swapped out dashes last weekend. PAIN IN THE ***!!!!
The very best thing is tho pull the steering wheel. If you can it's OK, just be a bit more carful, also behind the dash cluster is a mad group of wires that must go OVER a clip (you'll see what I mean) don't beake it, And you'll find one nasty zip tie--cut it.
Don't worry, my friend were pounding 40oz Coronas and we did it, and I've never done it
Old Nov 20, 2003 | 07:57 AM
94B&RZ-28's Avatar
The very best thing is tho pull the steering wheel. If you cant it's OK, just be a bit more carful, also behind the dash cluster is a mad group of wires that must go OVER a clip (you'll see what I mean) don't brake it, And you'll find one nasty zip tie--cut it.
Don't worry, my friend and I were pounding 40oz Coronas and we did it, and I've never done it
Old Nov 20, 2003 | 08:00 AM
cocheese's Avatar
Hey, i didn't have to do anything to make them fit. Who did you call or talk to? Mine are the 17x9.5's. I do recall measuring the backspacing to be safe, but there wasn't a problem, they fit perfectly. Just measure the backspacing and let whoever know. Sorry i can't remember the exact specifications.
Old Nov 20, 2003 | 08:04 AM
cocheese's Avatar
94B&RZ-28,
Did you just pop it out? Or did you have to remove any of the trim that goes along the doors (where the windows roll up to)? And does anything else have to be removed?
Old Nov 20, 2003 | 08:50 AM
94B&RZ-28's Avatar
You will have to remove the A-pillers and top dash (just pops out) All the 7mm (i believe) bolts, 2 screws and a handful of plastic push bolts. I'f you have an auto , pull the lever all the way to 1st gear and make damn sure you don't bend the key like I did. Remove the radio, HVAC, and the BCM. Seperate both halves of the glove box as well. The biggest bitch will be getting the dash over the top of the steering wheel. Since yours is allready broke, try and get it out without damaging it so you can see what your going to need to do to put the new one in. The biggest thing to remember is the plastic zip tie behind and to the left of the radio.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
chuyz28
Parts Wanted
Jan 7, 2015 05:25 PM
