Quick CC305 question
The 983 didnt fit in my engine. This is a part of a mail from Comp:
The correct spring that needs to be used is our 981-16 valve spring. You will have to remove the damper from these, but they will fit over your stock locator. The catalog does list the 983 spring, but it will not fit your locator and I do not make one for the LT1 engine. The 981 spring can use the 742 retainer which is 7 degree or the 950 retainer which is 10 degrees.
I got the 983 and i had to let a mech shop make new locators to me.
cheeper/easyer than shipping it back from sweden.
Originally posted by 97bowtie
I believe you will have to have the heads machined for those springs to work. I have the Crane 10308 springs - they are dual coil and are good to .600" lift w/no machining required. Something to look into.
But if i had this info from the begining i should have order the crane 10308-1 set insted.
Jan 23, 2015 01:13 PM
