question about heads/cam to finish 383, and DCR
well guys, im getting ready to get my car done, and am down to the heads/cam
ive talked to bret, and he said I would be perfect to go with LE3 heads and a LE4 cam, but i kinda want more than that.
I want to run mid to low 11's on motor with a properly setup car
i was thinking of running ported TFS heads and maybe a lunati voodoo cam (the biggest one) since it is about everything I am looking for out of a cam
this would give me around a 8.5:1 DCR tho, is this too high to run on pump gas?
I want a power band from 3500-6800 and the voodoo is right around that for a power band.
the car will have a 3600 stall, and 3.73 gears
8.5:1 DCR on pump gas will be fine, although it is at the higher limit. The Vodoo line of cams are proven, and if ya want to talk with the guy who designed those cams, PM me - he'd be glad to talk with you about matching the right heads to the cam and getting the gearing/stall combo correct.
My goals are just mid to low 11's (11.3 would be GREAT)
thanks seawolf, thats starting to look like the best option, slightly cheaper and more proven, but idk if i will get what i want out of it. Maybe they can do something slightly bigger for me cam wise
What's the difference between what you're calling the LE3 heads and the TFS heads?
I would talk to Lloyd and see what he recommended. If the TFS heads give you a lot more and you think they're worth the money, get them, but there's a lot more to head flow than CFM.
well, i know the flow numbers for the TFS is like 306 at 600
and the LE3s are like 280ish at 600
so....is the extra flow worth it, or what. I will talk to lloyd and see what he thinks i guess, eitherway he is getting my money so yeah
I've just always heard that custom is better than shelf grind. If I didn't have my cam already when I found out about those, then I would have bought one to save some money. I've seen some of the dyno graphs of what Bret has done and they look pretty darn good. I didn't mean to say that the Lunati cams weren't any good, they look awesome.
Do you have a copy of their lobe catalog?
