QTR times??
QTR times??
Ok. Me and My buddys rented US41 in Morroco, Indiana this Saturday for 8 hours. I am gonna bring my car there with the new motor and see what she,ll run. Just wanna see what kind of numbers you guys might think she will run.
95 Trans am w/ New style front end with fuctionally Ram air.
355 w/ LT4 heads ported and polished w/ all LT4 Hot cam conversion components.
52mm TB and 30 lbs SVO injectors
MSD 6al Ignition
2 3/4 Borla y-pipe, High flow cat and Magnaflow Cat-back
Tuned computer
3.73 gears with auburn posi
2600 stall with shift kit
Without the nitrous on E/T streets
Any ideas?
By the way. Me and my Buddy are running the track so if anyone wants to come. The more the better. We have the track this Saturday From 8 to 5. Email me or just show up. Its 30 bucks to run as many times you want in 8 hours. There is no tech to pass!
Just bring a Helmet for your own safety.
MSD 6al Ignition
Tuned computer
Any ideas?
Man I Pissed, I went to the track and Couldnt get any better then a 13.40. It was hot out today and the track is at 6200 level. I never spun the tires leaving the hole. I was running E/T streets and it hooked up great. I was stalling it to 2000 rpms before the light dropped. Think a dyno tune would help? It has to be something with the tune thats holding the motor back. I would think this car should be alot faster as my brother ran at the same track with a 94 camaro last year. He ran a 13.35 and his car is stock except for a MAF and 3.73 gears. Any ideas? Do you think long tubes would help it some??
Sorry about your bad luck today. It did get quite warm today. However I think you have some issues there. You should have been running mid 12's in my opinion... Do you have headers? What was your trap speeds? What kind of 60' times? I was running consistant 12.30 - 12.39 runs last year at that track with Hot Cam & Stock Heads on a stock short block. Does the car feel sluggish? I can tell from day to day when my car is running even just .3 tenths slower or faster by the seat of the pants.
The time was with 0 to 60 was 1.8 and speed of 103. Sorry about the 6200. I hit one to many zero's. I Do not have headers, Just ported Exhaust Maniflods. Just thought it would have run better. Any Ideas? Should I go get a dyno tune? I think the computer needs a better tune.
Ok, my advice is get some good longtubes, and the a dyno tune. If anything is wrong, and the puter is pulling timing, it is really killing your HP. I've seen a single degree of timing make as much as 23 RWHP difference on a dyno. When you consider the computer's ability to pull up to 4 degree's, that equates to nearly 100 HP worth of loss due to timing/tune.
My car trapped at 118 with a 6 speed at 3,000 feet with a semi-pro driver. You should crack 110 pretty easily with everything working right.
ChrisFrez
Feb 1, 2015 08:26 AM
