hmm that would work as well, either one would suffice. i can reach the plug fine, but the angle is just too great to get a socket on it, it hits the motor mount.
rob, you happen to know the size of that hole?
Not sure the p/n but any Mercruiser dealer or even a place like West Marine would have brass block drains that open easily[not sure theres clearance for it tho?
You gave me an idea there too I think I have one lying around here somewhere..
If I can find a pic I'll link it here..
there is clearance unless the valve in very very long. i could fit a socket and extension up to it, but the angle is wrong and it wouldnt fit w/o an extension, and then it hit the motor mount.
let me know if you find p/n or pic
Heres a link with a pic [not sure which of the 2 it is probably the 10.99 one[welcome to BOATS... if you think cars are $$$...
Also, pretty sure that plug is std 1/4" NPT
http://www.westmarine.com/webapp/wcs...=68&storeNum=6
I found one here, and it's about 1 5/8" total [screwed closed] and it will take about that much [minimum!]clearance installed, and to allow opening..
Not a bad idea, but make SURE it never opens on you tho...
Also, I have a type here that has a 'nut' with a drilling on the end..[instead of the petcock 'tee' ... same principle tho...]
Mercruiser p/n 22-16951A 1
ya wanna sell that one that you have?
so 2 inches of clearance will work?
i doubt it would open on the road just randomly? look at the radiator drain, mine has always stayed:-D and peoples catch can drains, etc.
Welll no it doesn't open easy[boats rock and roll too!
2 inches should work OK...
I have a used one, clean, just a few nicks, and tool marks [pliers etc] I wirewheeled it.. looks good... 8 bux shipped.. paypal OK..
I got 2, I'll keep one for the next flush..
Good idea there, if it fits OK[ it should if there's 2"]
]2 inches should work OK...
