CamaroZ28.Com Message Board
-   -   Pushrods for cam install... (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/pushrods-cam-install-697144/)
Diamhea Jul 3, 2009 06:33 PM
'94 Z28 with 113k.
I got the cc306 with patriot springs, put it in. Realized I needed Rockers. Got Comp Cams Magnum 1417-16 1.52 ratio ones. (Comp Cams tech recommended them). Then reading the paperwork for the rockers it says stock pushrods are a liability. Ok great.
Now I need to know of these will work with said rockers and the 306:
http://www.summitracing.com/parts/CC...w=16383&N=700+
If there is a cheaper/better alternative on SUMMIT (Imperative due to quick shipping and I need my car done by next week) let me know. Thanks guys.
Stl94LT1 Jul 3, 2009 07:08 PM
I like TrickFlow chromemoly pushrods.
http://www.summitracing.com/search/?...21407200&dds=1
lt1srule Jul 4, 2009 06:30 PM
1994 z28s have hardnd pushrods stock 1996 and 1997 did not so u will be fine..
Steve in Seattle Jul 4, 2009 06:52 PM
You don't need hardened pushrods... you don't have/need guideplates.
The Comp Cams Magnum 1417-16 are self-aligning rockers.
Stock was 5/16"... I use 3/8" pushrods for increased stiffness... either will work for you.
Smith Brothers make some great pushrods.
RamAir95TA Jul 4, 2009 07:21 PM
Should have went with full roller 1.6 rockers, not the Magnum 1.52s.
Steve in Seattle Jul 4, 2009 07:47 PM
Kind of off topic, but true. A little extra lift would have been nice I guess.
I use 1.6 Pro Mag NSA 7/16 RR's with my cam, but its a much different engine. Nothing wrong with 1.52's though...
Diamhea Jul 6, 2009 09:27 AM
I bought the Trick Flow chromemoly ones suggested earlier in the thread (Before all of these responses). I figure since the engine is already all dismantled putting them in isn't the worst way to spend ~$100..
