pushrod length question
Old Jul 10, 2005 | 03:32 PM
blackztpi's Avatar
alright. I see people sell 7.150 pushrods which are .050 shorter than stock. many people advertise them for milled heads. my question is, do you have to take off 50 thousandths of your heads or block deck to use these? my heads were milled .010 to true them up and the block is zero decked and the deck was ground down .010-.020. I can't remember which. My thing is, with my motor, would i be closer and better off trying a 7.150 pushrod and checking it for operation, or sticking with the stock ones? I can't say i've ever seen a set of heads milled .050 and i know that people with .020-.030 miled heads are using them just fine.
Old Jul 10, 2005 | 04:18 PM
Re: pushrod length question
The only way to truly determine the length you need is with an adjustable pushrod and checking the wear pattern on the top of the valve stem.
Old Jul 10, 2005 | 04:40 PM
Loadre's Avatar
i'm almost positive 7.2 isn't stock length
Old Jul 10, 2005 | 05:05 PM
1racerdude's Avatar
Ya need to check the geometry and see.Don't just think that because things have been cut ya can match the push rod length with the cut number's.
Ya got to measure.
Old Jul 10, 2005 | 05:24 PM
It is.
Old Jul 10, 2005 | 05:29 PM
Loadre's Avatar
Originally Posted by shoebox
It is.
Just kidding, I'm retarded. For some reason I picture looking at CMotorsport's site and it saying 7.2 was not stock, now that I go back and look it says it is stock. Shoebox is always right.
Old Jul 10, 2005 | 10:17 PM
blackztpi's Avatar
well, i expected that answer. i guess i'll try the 7.150's and do the wear pattern method.
Old Jul 10, 2005 | 10:35 PM
1racerdude's Avatar
Try stock before buying anything.Get the least width of the pattern as close to the center as ya can.
HectorM52
Jul 30, 2017 11:46 AM
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Roadie
Feb 16, 2015 10:34 AM
