problems.
ok, I had the new opti and waterpump installed yesterday, and now it wants to idle at around 600-700rpms, and would die when i put the brakes on to stop. I tried to turn the idle up by moving the screw on the TB up. The car seems a little sluggish. I mash the gas, then a second or two later it will take off, new clutch, so it isn't slipping.
Any ideas?
Any ideas?
my mechanic is the one who put it in, so i'm sure everything is hooked up. I have a chip from pcmforless. could the timing be messed up after the new opti install.
Could it be a faulty idle control valve????
You really should not mess with the idle screw. The IAC will override a small adjustment, anyway. My first thought is that the PCM is still learning after having the battery disconnected after your recent work. If so, the more you let it idle, the smoother/better it will get.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
