Problem with my LT1
Having a little problem with my lt1 and kinda stuck on what it could be. Ran it the other day to work(20min drive) ran perfect. When i left work tried to start it, would crank but wouldn't turn over so i looked at it today back at my house and noticed no spark and no fuel due to injector failure. The injectors look fine, coils great, everything seems to be in working order at first glance, but before i go checking every little bit someone mention to me earlier that it could be the computer failing? Any ideas or tips of what to look for would be helpful
thanks |
how do you know its injector failure? could possibly be a pcm gnd.
My brothers is doing the same thing. I have done some posting on here and some say it could be a leaky injector causeing the fuel system to lose pressure. It makes since. When your car does start do you notice any blue smoke from the tail pipes?
If there is no signal from the opti, you don't get spark or fuel injector operation.
clean it, if it doesnt work then its something else. start with the cheapest and simplest and move up.
Originally Posted by shoebox
(Post 4964121)
hmm, ill check the opti, I guess i ruled it out because its almost brand new, less then 1K miles on it, but knowing how sensitive they are i guess it could be.
thanks |
Before yanking the opti, very the opti cable is making good contact.
A simple scan would show up codes if the Opti isn't supplying the high and low res pulse signals. Why guess - scan it.
| All times are GMT -5. The time now is 09:37 AM. |
