pro mags and kr
pro mags and kr
I have tried everything. The last thing I done was adjust valves and just went a 1/4 turn then locked down. This lasted well around town with 0 kr for about 300 miles. Drove it to work today on the interstate about 30 miles and I check it with the scanner and I was getting 5 degrees once I stop at the light. The kr only comes up now when I give it a hard load. Any suggestions. Should I just change to the hot cam RRs.
so ur saying that you think that you're thinkin that the retard is coming from your rocker arms?
never heard of that before, but i am curious, cause i just found out this weekend that ive got A LOT of retard, about 1 at idle, then it can go up to 7.8 at wot, 5900 rpm.
i have hotcam rockers currently by the way, but i am putting on 1.7 scorpions this week.
ttt
ttt
ttt
ttt
But then again It could be my exhaust being so loud and vibration from it.
Sounds like a job for the LT4 knock module. The theory is that GM used a different module in the LT4 PCM that was less sensitive to knock being the LT4 had roller rockers arms that were more noisy.
Jeff D.
Jeff D.
Jeff D.
Jeff D.
been there, done that
somebody correct me if im wrong, but isnt what ur supposed to do is run some high octane gas, to check if its real knock, and as long as it goes away with the gas, u can then program it out?
