priming oil pump
Old Jan 3, 2005 | 11:30 AM
red 95 z28 lt1's Avatar
priming oil pump
im doing a le2 package on my car and everything going back in is being replaced (lifters pushrods, rockers etc.) i was wondering if you have to prime the oil pump. or if its ok to just soak everything in oil and crank the motor over a few times before i start it.
Old Jan 3, 2005 | 12:53 PM
Ken95Z28's Avatar
Re: priming oil pump
For just a simple cam swap, lifters, rockers you would not have to. Just make sure you lube up the cam pretty good on the journals and if you want soak the lifters and than install them. Crank the car up and watch the oil pressure. Make sure everything is clean before installing the cam.
Old Jan 3, 2005 | 03:29 PM
is there any kind of lube you put on the cam or just oil?
Old Jan 3, 2005 | 08:32 PM
Pasky's Avatar
Assembly lube is what I used. Just unplug the PCM, turn it over for a good 10-15 seconds and prime the oil. It won't hurt anything. Better safe than sorry.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NEWBIE T/A
Jun 14, 2002 12:27 AM
