Power Programmer Plus
Old Apr 29, 2003 | 02:37 PM
96HealyZ28's Avatar
Is the power programmer plus really worth $330? Does it make that much of a difference??
Old Apr 29, 2003 | 02:55 PM
LimitedEd1LE's Avatar
It should be called the HyperCRAP!!! The only thing that POS is good for is to recalibrate you computer for a gear change. Other than that it is worthless.
Old Apr 29, 2003 | 03:06 PM
The programming for performance is not that great and mostly only useful on a pretty much stock car.
It is useful for fan reprogramming, shift firmness and shift points (to a degree), gear ratio change and maybe another thing or two. It is not a good investment to buy a new one, when there are used ones out there for half the price or less. Just make sure that if you buy a used one, the programming has been removed from whatever car it was used on. It can only be used on one car at a time.
A laptop, cable and some programming software is the best value if you already have the laptop (or even desktop computer that can reach to your car).
The HPP has it's place, based on a person's particular needs. It's just that other solutions have made it less attractive.
Old Apr 29, 2003 | 03:46 PM
chesee48's Avatar
If i were you, i'd get mail order-custom programming through www.madz28.com or www.pcmforless.com
Both are WAY cheaper. Check them out.
Dec 1, 2014 08:08 AM
SLIMJIM
Jan 7, 2003 11:06 AM
XtremeLt1
Sep 13, 2002 08:50 PM
naaz90
Jul 27, 2002 08:22 AM
