power loss from EGR code?
Old Jan 30, 2005 | 11:02 PM
JDBlaze85's Avatar
yeah I have a 95 Firebird and it has only one code on the pcm which is the EGR code and I was wondering if performance or gas mileage will suffer any due to this?
Old Jan 30, 2005 | 11:06 PM
Bawls's Avatar
Re: power loss from EGR code?
Depends on what's going on. Is it a bad solenoid or a bad valve? If your EGR is bad, then yes you could be losing some performance/gas mileage.
Old Jan 31, 2005 | 05:33 AM
slopokrodrigez's Avatar
Is the code a 27 or 32?
Old Feb 1, 2005 | 07:14 PM
JDBlaze85's Avatar
the valve is stuck closed and needs replacing. Will this effect my performance/gas mileage?
Old Feb 1, 2005 | 07:32 PM
Bawls's Avatar
Talking Re: power loss from EGR code?
nope.
edit: yup
Old Feb 1, 2005 | 09:41 PM
If you get detonation from the lack of EGR, then yes, you will have a performance loss from spark retard.
Old Feb 2, 2005 | 05:23 PM
JDBlaze85's Avatar
would detonation be caused from the cylinders being extra hot from lack of egr flow?
and also, does the computer do anything to the fuel injection/timing to give you a power loss because the code is in memory? excluding the knock sensor.
HectorM52
Jul 30, 2017 11:46 AM
edman
Mar 13, 2015 09:39 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
