power brakes no workie
well everyonce in a while, im starting to get confused
i have no power brakes, im sitting at the light using all my muscle to stay on the line. why is this? its not very consistant |
what is the car idling at?
probably about 900 or so
anyone, this would save me some leg muscles that i dont really have :cry:
its usually right after i start my car but sometimes it'll be after i went about 5-6 miles its just i donno what its all about, im pressing as hard as i can my leg is getting tired and if i stop pushing the car lurches forward all brake pads are new |
do you have a big cam in there or something?
Vacuume leak of some kind I'd guess. I think you can turn the car on, and spray carb cleaner (just a little) near your vacuume lines (especially your break booster) and see if the idle changes or stumbles. For the record I have never checked for leaks this way, just hear of someone else on this board doing it ;)
You can also use a vacuum gauge on the brake booster line, check the the plastic fitting going into the booster.
