Which poly motor mount recommendation?
Old Sep 20, 2005 | 08:27 PM
2QUIK6's Avatar
Which poly motor mount does everyone recommend?
Old Sep 20, 2005 | 11:10 PM
2000GTP's Avatar
Re: Which poly motor mount recommendation?
Have yet to install, but I picked up a set of Prothane poly mounts from Summit for 40.00.
Old Sep 20, 2005 | 11:22 PM
turbo_Z's Avatar
I have a prothane on the pass side and an ES on the drivers side. The material looked and felt exactly the same. So I dont see any difference other than what you can get ahold of the easiest and cheapest is your best bet.
Old Sep 21, 2005 | 09:04 AM
2QUIK6's Avatar
Thanks, are these the Summit ones you have ?
http://store.summitracing.com/partde...=KeywordSearch
Old Sep 21, 2005 | 09:46 AM
LWillmann's Avatar
I ordered my set from Thunder. Very happy.
Old Sep 21, 2005 | 01:08 PM
Bawls's Avatar
Same. Prothane brand, very nice.
Old Sep 28, 2005 | 07:46 PM
93 4mula's Avatar
So vibrations just are a little bit worse when changing to poly motor mounts? Does it effect anything if you have a big motor with a large cam? Also whats this about auto's vibrating really bad when putting poly tranny mount in? It wont do it with a M6 will it?
Are these any good?
http://store.summitracing.com/defaul...=KeywordSearch
Old Sep 28, 2005 | 07:57 PM
1racerdude's Avatar
Poly trans mount will do it with either tranny.
Old Sep 28, 2005 | 09:20 PM
93 4mula's Avatar
So basically just get a New Stock tranny mount and run that? What about the motor mounts?
Old Sep 28, 2005 | 09:24 PM
Bawls's Avatar
A lot of people run the 1LE tranny mount. A little beefier then the stock LT1 replacement, less vibration then a poly mount.
For your motormounts, I recommend the prothane mounts from thunderracing. I've had mine for about 8 mo. now. No complaints.
Old Sep 28, 2005 | 09:40 PM
2QUIK6's Avatar
That Summit part# in your link is the part for 1st and 2nd gens. LT1 part # is PTP-&-508-BL for the motor mounts.
GM does not make the 1LE tranny mount anymore, the best bet for a better than stock replacement without getting the poly mounts to to use the stock LS1 tranny mount, it is harder rubber than the stock LT1.
Old Sep 28, 2005 | 11:26 PM
asudecat's Avatar
Well I just ordered the Motor mounts, tranny mounts, front control arm bushings, torq arm bushings as well from Thunder racing.
Was this a bad Idea with the Poly tranny mounts?
Old Sep 29, 2005 | 04:06 AM
mattbailey's Avatar
I've run my prothane motor mounts for over 2 years, no problems. I also have a ES tranny mount.
Old Oct 10, 2005 | 02:57 PM
2QUIK6's Avatar
I installed the prothane poly mounts w/e before last and they perform great. no more engine rocking and no noticable vibrations either...thanks all for the recommendation!
Old Oct 10, 2005 | 04:35 PM
96ta(nick)'s Avatar
i went through 3 stock tranny mounts in a little over a month and decided to switch to a poly along with poly motor mounts. I noticed a little more vibration but with the dumps and big cam the whole car vibrates anyway..
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:34 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
