Poly Lock tips
Old Jul 23, 2004 | 03:16 PM
disco192's Avatar
Poly Lock tips
Alright, my rockers are driving me insane. I have the comp pro magmum NSA 1.6 rockers and ive set the lash about 3 times now. Every time they stupid rockers find a way to back the hell out on me. 1st time i had 3 back out completely and then just one. It does this after about 50-200 miles driving.
Could it be that i am not setting the lash right? I am thinking about putting the stock rocker nuts on to keep the bastards in place. I assume threadlock would be a BAD idea.
You guys got any tips that can keep my rockers from comming off? Or should i just get a 12" allen wrench and torque the CRAP outta the poly locks?
Thanks,
Stu
Old Jul 23, 2004 | 04:01 PM
Ekof96Z28's Avatar
Re: Poly Lock tips
To get mine to stay so far(only been a few hundred miles, but some drag strip raping as well) I bought a allen key set on a handle... folded the handle out and used it kinda like a T-handle... went as tight as I was comfortable without breaking the tool.... so far soo good. If you get them tight enough you can kinda feel them sorta lock into place...
Old Jul 23, 2004 | 04:03 PM
Pasky's Avatar
Re: Poly Lock tips
Buy a ratchet and socket with a allen extension for the poly locks, I tightened the **** out of mine with the ratchet after trying 3 times by hand with an allen wrench and they no longer come loose.
Old Jul 23, 2004 | 04:15 PM
Mtrhds94Z's Avatar
Re: Poly Lock tips
Most people turn both the 'lock' AND the 'adjustment nut' a little tighter.. [turn both TOGETHER]
This method seems to work well..
Aaront810
Aug 29, 2020 09:34 PM
colts0455
Oct 4, 2015 09:47 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
colts0455
Sep 27, 2015 01:07 PM
autoxr166
Sep 25, 2015 04:21 PM
