which plug wires? taylor or msd?
gonna pick up some new wires.........ive seen msd for about $65, taylor for $50, and others for even more..........which should i go with, and why?
I like the Taylors...I have had a friend that used the MSD and now he is using the Taylors. He says he likes the Tayors better too.
The Taylors (I was told) have a better spark plug boot than the MSD. I was told the MSD have been known to break if you try to tug on them too hard (off the plug). I have had taylors for about 5 months now and are very pleased with them.
Hope that helps,
Claude
Hope that helps,
Claude
Originally posted by wannabe96z
I'd like to know where you guys are finding wires that cheap, i went to advance and they said that acdelco plugs were 132 dollars
thunderracing (in the vendor index) has them for $50
U can get the Taylors here as well:
http://www.ls1speed.com/catagory.cfm?catagory=pcm
Thanks,
Claude
Thanks,
Claude
I was going to go w/the MSD wires but I found out they don't fit in the stock looms so I think I'll be going with the Taylors. The only thing I don't like is that I can only choose between red and blue wires
