please respond!!!!!
please respond!!!!!
i am having a noise comming from my rear end i believe only when i go in reverse...not drive or nothing...any clues on this?
and sometimes when i turn my wheels really hard to the left or right i hear a whine...i know im not low on power steering fluid but what could this be also?
randy
randy
Does it do it several times or just once. If it does it just once, it may be the U-joints. Several pops when backing up, you may need to take the rear diff cover off and look around, Something may be going out in the rear end.
dang, cuase i just had gears changed, cause my 1st set of 3.73's were stripped then i put in new 3.73s and now it didnt do it at 1st but now it is making that sound when in reverse....
so maybe back lash is set wrong? take it back and have them take a look...cause i hope i didnt strip my gears again!!!
Originally posted by shoebox
No (or wrong) limited slip additive can make it make a ton of noise (snapping, popping, groaning) when backing and turning at the same time.
So I guess I'll just second that...
When I bought my Z I got $500 taken off the price for the popping sound in the rear. Changed the fluid and put in additive and voila 15 nitto DR lanuches on the track pulling a 1.7 60'
well earlier today, i went to oreilly and i was backing up out of my driveway and i didnt hear a thing...and last night my ac started working again after like 1-2 months...i havent had ac that long and all the sudden it works? my car is a CONSPIRACY!!!
Originally posted by JoeliusZ28
my car has always made a very faint popping when turning in reverse... I always figured it was the limited slip and was normal.
steelerfan
Jul 2, 2015 09:54 PM
Jul 2, 2015 11:39 AM
[Problem] F-Bodyworld.com/Jon Massaro WARNING!!
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
