please help w/ timing chain! which for electric wp
Old Nov 13, 2003 | 12:54 AM
YOSHI`S Z28's Avatar
hi,
i am installing a csi electric waterpump and new timing chain.
now that i have a electric water pump its not cam driven, does that bear anything on the size or style of timing set? i heard now i can use a cloyes double roller set up or one similar. is this correct?
can some one help me choose a timing set or let me know which one there using with a electric wp
thanks,
josh
Old Nov 13, 2003 | 12:58 AM
madwolf's Avatar
Go with the Cloyes. It will work with the CSI just fine plus it's not too expensive.
Old Nov 13, 2003 | 01:08 AM
thanks mad wolf
thanks mad wolf,
would you possibly know the part number for one, or possibly where to get one?
i looked in the summit catalog and the only one they had for a sbc said {except factory roller cam} is that the one i need to get?
$67.95 ??
thanks for your help,
josh
Old Nov 13, 2003 | 01:11 AM
madwolf's Avatar
Not sure about Summit's part number, but Combination Motorsports carry it.... linky.
Old Nov 13, 2003 | 06:22 AM
Mtrhds94Z's Avatar
Don't you also need a vented opti, and a cam with the nose drilling to do that on a 94?
Old Nov 13, 2003 | 07:37 AM
Yes, because the Cloyes cam gear does not have the drive splines to run the non-vented opti.
Old Nov 13, 2003 | 09:25 AM
madwolf's Avatar
Ooops, I didn't pay attention that he had a 94.... Yes, there is not much choice on a 94 as far as the timing chain goes, without a vented opti conversion.
Best thing you could do without converting is getting a new stock chain and new cam/crank sprockets.
Lunati also makes a replacement chain that would work on your car (summit carries it) but nobody here tried it yet...
Old Nov 13, 2003 | 10:37 AM
how hard is it to change to a vented opti? would it be worth my time and how much money does that take.
someone said something about drilling the cam?
im confused
josh
Old Nov 13, 2003 | 10:42 AM
madwolf's Avatar
I'd save that for when you do a cam install.
You will need a cam with a longer dowel pin to drive the opti, you will need a vented opti, vented opti harness, vented opti vacuum harness, 95 timing cover and of course, the chain and sprockets.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
