Please help me with this frustrating problem!
Old Mar 2, 2003 | 11:58 PM
problemCar's Avatar
Old Mar 3, 2003 | 01:02 AM
Pandamonkey's Avatar
Is the check engine light coming on?
It may be as simple as a clogged fuel filter.........
Old Mar 3, 2003 | 01:05 AM
VegasZ's Avatar
Mine had a similar problem of dying but only when taking sharp turns. Ended up being a bad battery. I would check your battery and battery terminals. Make sure theyre free of corrosion and tight.
Old Mar 3, 2003 | 09:50 AM
problemCar's Avatar
check gauges lite come on right before it dies, like 2 secs before hand. battery and terminals are fine.
Old Mar 3, 2003 | 11:40 AM
You can check to see if it is the fuel pump by putting a pressure tester on it when it won't start. Obviously, the only time you can find an intermittent problem is when it is happening. You just have to keep proving and ruling things out until you find it. Put a fuel pressure test gauge in the car so someone can hook it up and look at it next time it dies.
It also could be an overheated electrical component. My bet is the fuel pump, though.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
