Please help asap..no start and back firing
Old 11-15-2018, 08:23 PM
Marshmaro's Avatar
I don't mean to double post but my prior one was in the wrong category
I gave 8t a decent amount of throttle from a stop and the Trac control kicked on and it back fired about 5 tines then died.. It now won't start and back fired still. I only cranked it with and without giving it throttle both with the same result,nothing..fuel pump primes and it's throwing no codes that would pertain to this. Could is be my crank shaft position sensor? The car occasionally did have a longer than normal crank at start and sometimes would run for a second or two after I turned off the ignition .. It is a 1997 z28 lt1 a4..
Marshmaro is offline
Old 11-15-2018, 11:06 PM
Re: Please help asap..no start and back firing
Please don’t post the same topic on multiple forums. I saw your duplicate on “Advanced Tech” first, and wasted my time moving it here to “LT1 Based Engine Tech”.
Injuneer is offline
Marshmaro
12-02-2018 09:06 PM
warmeck
09-02-2014 06:23 PM
96Z28Camaro4
06-17-2010 08:40 PM
jonathan_abilene
02-12-2007 01:26 PM
fbird95
04-07-2003 08:37 AM
Quick Reply: Please help asap..no start and back firing
