CamaroZ28.Com Message Board
-   -   Pinging after opti install.... (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/pinging-after-opti-install-124774/)
n2ceptor May 25, 2003 03:13 PM
93 Camaro - replaced cap and rotor- engine started up ok, ran good for 5-10 seconds then started to idle up and down (700- 1100 rpms)
I rev to 2500rpms seems OK..... Took a drive, under load starts pinging..... normal accel no problem... passed 1/2 throttle, pinging again...
Question, is the rotor off by a tooth or two to cause this??? OR any other suggestions...
Did search, couldnt find anything on this....
P. S. motor is stock......
93Z Will
95z28 -quicksilver May 25, 2003 03:17 PM
Did you make sure the opti is 100 percent flush with the block??? If not that might be the cause of your problems.......just something to check.
Chris
n2ceptor May 25, 2003 04:21 PM
opti is flush, any one else?
95z28 -quicksilver May 25, 2003 04:24 PM
Did you make sure you hooked up the vacuum lines to the opti. There are 2 of them and if they are not hooked up then that could be the cause of your problems...........
Chris
n2ceptor May 25, 2003 04:31 PM
its a 93' non-vented.......
95z28 -quicksilver May 25, 2003 05:12 PM
HMMMMMMMMMMMMMM...............you got me then. I dont know wha to tell you. Im sure SHOEBOX could give you some insight to your situation. Just an idea. He has helped me many times with my car when it ****s up.
Chris
