Pinging after opti install....
Old May 25, 2003 | 03:13 PM
n2ceptor's Avatar
93 Camaro - replaced cap and rotor- engine started up ok, ran good for 5-10 seconds then started to idle up and down (700- 1100 rpms)
I rev to 2500rpms seems OK..... Took a drive, under load starts pinging..... normal accel no problem... passed 1/2 throttle, pinging again...
Question, is the rotor off by a tooth or two to cause this??? OR any other suggestions...
Did search, couldnt find anything on this....
P. S. motor is stock......
93Z Will
Old May 25, 2003 | 03:17 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Did you make sure the opti is 100 percent flush with the block??? If not that might be the cause of your problems.......just something to check.
Chris
Old May 25, 2003 | 04:21 PM
n2ceptor's Avatar
opti is flush, any one else?
Old May 25, 2003 | 04:24 PM
Did you make sure you hooked up the vacuum lines to the opti. There are 2 of them and if they are not hooked up then that could be the cause of your problems...........
Chris
Old May 25, 2003 | 04:31 PM
n2ceptor's Avatar
its a 93' non-vented.......
Old May 25, 2003 | 05:12 PM
HMMMMMMMMMMMMMM...............you got me then. I dont know wha to tell you. Im sure SHOEBOX could give you some insight to your situation. Just an idea. He has helped me many times with my car when it ****s up.
Chris
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
