PCV valve replacement
102k miles and I believe the original PCV valve is in there. Is there any trick to replacement?
I just did this last week. Very simple. There is a Vacuum T-fitting in the way I had to pull and then there is the hose to the PCV. Pull that and pull the PCV. Very easy. It took less than a minute.
Get an AC-Delco replacement as others have been known to be a little small in diameter and not fit properly.
So the O'Reilly house brand I bought is junk? ****....$1.49 down the drain. :cry:
Originally Posted by Texas_96_Z
(Post 4501537)
| All times are GMT -5. The time now is 08:14 AM. |
