PCV valve replacement
Old Mar 26, 2007 | 04:32 PM
Texas_96_Z's Avatar
102k miles and I believe the original PCV valve is in there. Is there any trick to replacement?
Old Mar 26, 2007 | 04:45 PM
Gtpguy's Avatar
I just did this last week. Very simple. There is a Vacuum T-fitting in the way I had to pull and then there is the hose to the PCV. Pull that and pull the PCV. Very easy. It took less than a minute.
Old Mar 26, 2007 | 04:53 PM
Get an AC-Delco replacement as others have been known to be a little small in diameter and not fit properly.
Old Mar 26, 2007 | 08:09 PM
Texas_96_Z's Avatar
So the O'Reilly house brand I bought is junk? ****....$1.49 down the drain.
Old Mar 26, 2007 | 10:59 PM
You can try it. There is no guarantee it won't work.
HectorM52
Jul 30, 2017 11:46 AM
grgguy
17
Feb 23, 2015 07:57 PM
Jazsun
Dec 29, 2014 12:14 PM
