PCV Valve in a 97
Old Apr 28, 2008 | 10:30 PM
DrRuckus13's Avatar
PCV Valve in a 97
Quick question... Got a 97 and changed the PCV valve this weekend and it seems to be really loose in the engine. Does anyone know if there is supposed to be some type of rubber grommet or sleve it should sit in? It just slides in and out with only the rubber hose holding it in place? seems like it could fall out.
Old Apr 28, 2008 | 10:42 PM
The Engineer's Avatar
There should be a rubber grommet in the intake manifold that holds PCV valve. The PCV valve and grommet are in the top and center of this photo.
WD
Old Apr 28, 2008 | 11:00 PM
DrRuckus13's Avatar
although my crappy little stocker looks nothing like yours The rubber must be melted around the hole leaving to much of a gap. the connection hose actually pulled it out about a 1/4 inch and the valve is not exactly flush with the engine.
TY
Old Apr 28, 2008 | 11:12 PM
If you replaced it with anything but a genuine AC-Delco, it may be loose. Other brands have reported to not fit as tightly.
14
Aug 11, 2015 12:03 PM
surreybrad
Aug 10, 2015 09:34 AM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
